It is currently Fri Jul 18, 2025 11:51 pm
PostPosted: Wed Oct 10, 2007 12:51 pm
Last Name: Sterling
City: Ulster Park
State: New York
Zip/Postal Code: 12487
 Visited a local Luthier yesterday and saw something really slick and I am going to steal the idea. He had a spring loaded go-bar made from a 1/2 dowel a spring and 1/2 inside diameter pvc pipe. On one end of the pipe was a plug made of a short piece of dowel covered with leather. Then a spring went into the pipe and a length of dowel was on top of the spring. The long length of dowel was held in the pipe by a small wood screw that rode in a slot to give you your movement. When I get one made I will post a picture. I like the idea because the go-bar can sit squarely on the braces because they aren't bent. Tom Humphrey the luthier was the one that came up with the idea.
Mistakes are mandatory-learning from them is optional. http://www.opensourceluthiersupply.com
PostPosted: Wed Oct 10, 2007 2:09 pm
You mean, like this, sort of?
I saw something similar on a website showing a similar type of go-bar that a student of Romanillos was using, and found out that Romanillos uses a similar type.  Mine is a simpler form than the one I saw.  It is not quite finished yet, and this is the prototype of my design.
PostPosted: Thu Oct 11, 2007 2:32 am
Julius Borges uses something very similar to those as well. My favorite go-bar idea (which I haven't tried yet) is from John Osthoff, A go bar on a lazy susan to make for easy cleanup.
PostPosted: Thu Oct 11, 2007 7:49 am
Last Name: Shaw
City: Phila
State: PA
Zip/Postal Code: 19125
I have seen footage of a gibson acoustic factory and they use something similar to this. Theirs use a spring loaded dowel in copper pipe. Theirs were only 6 to 8 inches long and they were used in a similar hight go bar deck.
PostPosted: Thu Oct 11, 2007 12:33 pm
First name: Heath
Last Name: Blair
City: Visalia
hmmm... 8" long (or whatever length) spring loaded dowels in a short go bar deck (wheels turning)... if the top of the go bar deck were clear, this could be pretty cool. just a thought. i dont know if thats enough room to move around in.
sweat the small stuff.
PostPosted: Thu Oct 11, 2007 2:48 pm
Seems like it would be hard to clean up glue squeeze-out if the top was that close.
PostPosted: Thu Oct 11, 2007 4:18 pm
First name: Heath
Last Name: Blair
City: Visalia
definitely
PostPosted: Fri Oct 12, 2007 4:04 am
Heck, my springs are 5" long fully extended.  It'd be hard to make one only 8" long.  I struggled to find springs that had enough travel to give clearance so you could insert the bars with a little flexibility.  I figure on making some 3 3/4" inserts for the top end so I can have a fixed height for the deck top, and still use the bars for both braces and installing backs.
PostPosted: Fri Oct 12, 2007 2:50 pm
Last Name: Shaw
City: Phila
State: PA
This was old factory footage. If i can find it again i'll post it. They don't use this any more. At least i don't think they do. I have seen newer footage of them using vacuum press' for bracing.
PostPosted: Fri Oct 12, 2007 3:00 pm
Last Name: Shaw
City: Phila
State: PA
Her is the link to a picture tour of gibson montana from 1997. You'll se e the go bar deck.
http://www.gibson.com/products/montana/tour/tour1a.html
PostPosted: Fri Oct 12, 2007 3:02 pm
Last Name: Shaw
City: Phila
State: PA
Their probably more like 10" long.
PostPosted: Fri Oct 12, 2007 3:44 pm
    Before I went to vacuum systems for clamping my bracing, I used go bars
that were made from 3/8" solid aluminum rods inside 3/8" I.D. aluminum
tubing with a 5" long spring against a pin through each one.
    They provided nice consistent pressure and were adjustable by moving
the pin into any of a series of holes along thet tubing.
Regards,
Kevin Gallagher/Omega Guitars
Users browsing this forum: Bing [Bot] and 8 guests
